It is currently Sat Jun 21, 2025 7:24 am
PostPosted: Fri Jan 20, 2006 2:03 pm
I just read the tread on bending Koa and I am about to bend a set of high figure walnut....my first set of walnut. Is there anything I should watch for before I bend? Temp?
peterm38737.9219907407
PostPosted: Fri Jan 20, 2006 2:07 pm
The stuff bends like plastic. Walnut is very forgiving.
Any high curl woods can be a challenge, but walnut is about as easy as they come.
PostPosted: Fri Jan 20, 2006 5:53 pm
I like to bend Walnut. It's pretty forgiving, but Brock is correct about curl.
PostPosted: Fri Jan 20, 2006 10:37 pm
    If you are using the machine , the bending technique is the same as for figured Koa . If you are bending by hand the use of a flexible plate over the iron helps to keep the figure from potato chipping
john hall
